はじめに
This guide provides a walk through of the steps needed to remove the enclosure in order to access the internal parts of the Canon PowerShot SX10 IS . The front and rear casings protect the internals of the Canon PowerShot SX10 IS from debris and damage.
Replacing the rear and front casing might be necessary in instances where the camera has been damaged or if the camera is in need of maintenance. Repairing the rear and front casing of the camera will resolved the issue of a damaged case and will also renovate the outer design. This guide provides comprehensive instruction to disassembling the casing of the camera.
There is no specific training required prior to executing the guide. However, organization and the use of the proper tools will be crucial in the replacement process.
It is important to note that reassembly of the camera can be accomplished by following the provided steps in reverse.
必要な工具と部品
Open the door. Release the catch by sliding it towards the side of the camera.
Then slide the door towards the front of the camera.
この手順で使用する道具:Tweezers$4.99
Remove two cables connected to the motherboard.
Use thin tweezers to push down on the clear piece and slide it out. At this point half of the clear piece should be free.
Remove one screw that is holding down the middle of the clear piece to the body of the camera. The whole structure with wires will swing out.
Using the iFixit opening tool, gently pry along the top edge of the front casing.
Move to the right side of the camera and gently pry at the top and bottom areas of this part of the casing. The front casing will come free once it has been pried here.
The front casing will be able to slide away from the body of the camera.
