パーツ
パーツは必要ありません。
  1. Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen. Remove the 2 screws(4.08mm) on the other side.  One is located under the rubber USB flap. Remove the last screw(2.59mm) located on the bottom of the camera.
    • Remove the 2 screws(2.41mm long) on the side of the camera next to the LCD screen.
    • Remove the 2 screws(4.08mm) on the other side. One is located under the rubber USB flap.
    • Remove the last screw(2.59mm) located on the bottom of the camera.
    • Slowly pull the back cover of the camera.
  2. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  3. Remove the screw(2.59mm) from the bottom of the camera. Remove the screw(4.08mm) from the menu button side of the camera. The 2 screws on the other side of the camera were already removed when taking off the back cover.
    • Remove the screw(2.59mm) from the bottom of the camera.
    • Remove the screw(4.08mm) from the menu button side of the camera.
    • The 2 screws on the other side of the camera were already removed when taking off the back cover.
まとめ
Robert Manno
メンバー登録日: 2011年01月05日
432 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 13-3, Forte Winter 2011 Cal Poly, Team 13-3, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S13G3
5 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,676
