はじめに
You will need a #00 Philips Screwdriver. The prerequisites for this guide include removing the casing and removing the LCD screen.
必要な工具と部品
Turn the camera to the side that has the attachment for the wrist strap.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Flip the camera right side up.
Remove the silver 3.5 mm screw (located on top of the camera) with a #00 Phillips screwdriver.
Grip the corner of the A/V digital port and pull up and outward.
この手順で使用する道具:Tweezers$4.99
Locate the two ribbons connected to the camera and the LCD screen. (One is red and small and the other is wide and orange)
Remove the top left red ribbon by gripping the connector on the camera and sliding it straight out.
Remove the side orange ribbon by gripping the connector on the camera and sliding it straight out.
Remove the plastic and rubber circular button from the back of the camera by lifting it with your fingers.
ある他の人がこのガイドを完成しました。
