メインコンテンツにスキップ
Canon Powershot SD750 Camera Case Replacement
必要な工具と部品
  1. Canon Powershot SD750 Camera Case Replacement, Camera Case: 手順 1、 1の画像 1
    • Turn the camera to the side that has the attachment for the wrist strap.
    • Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
  2. Canon Powershot SD750 Camera Case Replacement: 手順 2、 1の画像 1
    • Remove the plastic subsection by prying it with your fingers.
    • Note: It may be helpful to pry from the bottom of the camera with the battery door open.
    • The wrist strap attachment behind the subsection will come loose and may fall out.
  3. Canon Powershot SD750 Camera Case Replacement: 手順 3、 1の画像 1
    • Turn the camera over to the side opposite of the wrist strap.
    • Remove the two silver 3.4 mm screws with a #00 Phillips screwdriver.
  4. Canon Powershot SD750 Camera Case Replacement: 手順 4、 1の画像 1
    • Flip the camera upside down.
    • Remove the following screws with a #00 Phillips screwdriver.
    • One black 3.4 mm Phillips screw.
    • One silver 3.4 mm Phillips screw.
    • NOTE: Using your fingernails may help in removal.
  5. Canon Powershot SD750 Camera Case Replacement: 手順 5、 1の画像 1
    • Place the camera on the side opposite of the wrist strap handle.
    • Then begin to pry the casing apart with both hands by applying pressure to the top and bottom of the camera.
    • Remove the small metal plate underneath the plastic covering and set aside. (It should be loosely attached)
    • Note: A rubber foam washer that separates the lens from the casing will fall off when the case is removed. Be sure to store it safely.
    • Note: When reassembling ensure the back plate screw tabs are over the wrist strap attachment and the front plate screw tabs go under orange casing.
終わりに
5 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
Memphis Wong
メンバー登録日: 09/30/10
73 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-37, Forte Fall 2010 Cal Poly, Team 14-37, Forte Fall 2010人のメンバー
CPSU-FORTE-F10S14G37
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 3,706
