メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Canon Powershot SD550 Outer Case Replacement
必要な工具と部品
  1. Canon Powershot SD550 Outer Case Replacement, Outer Case: 手順 1、 1の画像 1
    • In preparation for disassembly, the battery and SD Card need to be removed from the camera. You can access both the battery and the SD card through the door on the bottom of the camera.
  2. Canon Powershot SD550 Outer Case Replacement: 手順 2、 1の画像 1
    • While being careful to remember the original location of each screw, remove the three 0.15 inch screws on the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Outer Case Replacement: 手順 3、 3の画像 1 Canon Powershot SD550 Outer Case Replacement: 手順 3、 3の画像 2 Canon Powershot SD550 Outer Case Replacement: 手順 3、 3の画像 3
    • Find the next two screws on the right side of the camera. One of them is hidden under the USB port cover. The upper screw is .125 inches long, while the lower screw measures .085 inches.
    • Remove both screws, then carefully lift the side panel off.
    • Underneath the side panel, there is a .07 inch screw. Remove it.
  4. Canon Powershot SD550 Outer Case Replacement: 手順 4、 3の画像 1 Canon Powershot SD550 Outer Case Replacement: 手順 4、 3の画像 2 Canon Powershot SD550 Outer Case Replacement: 手順 4、 3の画像 3
    • On the left side of the camera, there are two .085 inch screws. Remove these, then lift the plate from the camera.
  5. Canon Powershot SD550 Outer Case Replacement: 手順 5、 3の画像 1 Canon Powershot SD550 Outer Case Replacement: 手順 5、 3の画像 2 Canon Powershot SD550 Outer Case Replacement: 手順 5、 3の画像 3
    • Now the camera body is loose. gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Outer Case Replacement: 手順 6、 3の画像 1 Canon Powershot SD550 Outer Case Replacement: 手順 6、 3の画像 2 Canon Powershot SD550 Outer Case Replacement: 手順 6、 3の画像 3
    • Next, remove the front of the camera body. Be sure to keep track of the rubber ring.
    • You have now successfully removed the outer case.
終わりに
作成者
4人の作成者と共同で作成されました。
Matthew Theiss
メンバー登録日: 04/14/11
176 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G23
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,560
