メインコンテンツにスキップ
Canon Powershot SD550 Motherboard Replacement
必要な工具と部品
  1. Canon Powershot SD550 Motherboard Replacement, Outer Case: 手順 1、 1の画像 1
    • Remove the battery and SD card from the camera.
  2. Canon Powershot SD550 Motherboard Replacement: 手順 2、 1の画像 1
    • Remove the three 3.8 mm screws from the underside of the camera.
    • Each of the screws is slightly different, so it is important that you note the original location of each screw.
  3. Canon Powershot SD550 Motherboard Replacement: 手順 3、 3の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 3、 3の画像 2 Canon Powershot SD550 Motherboard Replacement: 手順 3、 3の画像 3
    • Remove the 3.2 mm screw from the right side of the camera.
    • Remove the 2.2 mm screw from the right side of the camera.
    • One of these screws is hidden under the USB port cover.
    • Lift the side panel off.
    • Remove the 1.8 mm screw from underneath the side panel.
  4. Canon Powershot SD550 Motherboard Replacement: 手順 4、 3の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 4、 3の画像 2 Canon Powershot SD550 Motherboard Replacement: 手順 4、 3の画像 3
    • Remove the two 2.2 mm screws from the left side of the camera.
    • Lift the plate from the camera.
  5. Canon Powershot SD550 Motherboard Replacement: 手順 5、 3の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 5、 3の画像 2 Canon Powershot SD550 Motherboard Replacement: 手順 5、 3の画像 3
    • Gently lift the rear of the case to remove it from the camera.
  6. Canon Powershot SD550 Motherboard Replacement: 手順 6、 3の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 6、 3の画像 2 Canon Powershot SD550 Motherboard Replacement: 手順 6、 3の画像 3
    • Remove the front of the camera body.
    • Be sure to keep track of the rubber ring.
  7. Canon Powershot SD550 Motherboard Replacement, LCD Screen: 手順 7、 3の画像 1 Canon Powershot SD550 Motherboard Replacement, LCD Screen: 手順 7、 3の画像 2 Canon Powershot SD550 Motherboard Replacement, LCD Screen: 手順 7、 3の画像 3
    • Peel the navigation buttons from the button panel and set them aside.
    • To free the LCD display, remove the 2.9 mm screw in the top left corner.
    • Rotate the screen clockwise until it lifts away from the camera.
    • There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
  8. Canon Powershot SD550 Motherboard Replacement: 手順 8、 2の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 8、 2の画像 2
    • To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
    • After disconnecting both cables, pull the screen away from the camera to remove it.
  9. Canon Powershot SD550 Motherboard Replacement, Motherboard: 手順 9、 2の画像 1 Canon Powershot SD550 Motherboard Replacement, Motherboard: 手順 9、 2の画像 2
    • Remove the two 3.4 mm screws still holding the button contact panel onto the camera.
    • Using the spudger, disconnect the ribbon cable attaching the button contact panel to the motherboard.
    • Gently pull the button contact panel away from the motherboard.
  10. Canon Powershot SD550 Motherboard Replacement: 手順 10、 2の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 10、 2の画像 2
    • Underneath the button contact panel, you will find a large connector.
    • Using the spudger as leverage, unplug the connector, and pull it away from the motherboard.
  11. Canon Powershot SD550 Motherboard Replacement: 手順 11、 3の画像 1 Canon Powershot SD550 Motherboard Replacement: 手順 11、 3の画像 2 Canon Powershot SD550 Motherboard Replacement: 手順 11、 3の画像 3
    • The last ribbon is held in place by the blue flap. Insert the spudger under the blue flap.
    • Using the spudger as leverage, flip the blue flap up, which will unlock the ribbon.
    • Place the spudger into the hole in the ribbon, and pull the ribbon away from the connector.
  12. Canon Powershot SD550 Motherboard Replacement: 手順 12、 1の画像 1
    • Remove the motherboard by pulling it out with either tweezers or the spudger.
終わりに
作成者
6人の作成者と共同で作成されました。
Luke Thompson
メンバー登録日: 04/17/11
11 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-23, Garner Spring 2011 Cal Poly, Team 18-23, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G23
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,579
