Remove the three 3.8 mm screws from the underside of the camera.
Each of the screws is slightly different, so it is important that you note the original location of each screw.
Remove the 3.2 mm screw from the right side of the camera.
Remove the 2.2 mm screw from the right side of the camera.
One of these screws is hidden under the USB port cover.
Lift the side panel off.
Remove the 1.8 mm screw from underneath the side panel.
Peel the navigation buttons from the button panel and set them aside.
To free the LCD display, remove the 2.9 mm screw in the top left corner.
Rotate the screen clockwise until it lifts away from the camera.
There are two ribbon cables attached to the rear of the screen. Do not try to pull the screen off at this point.
To unplug the ribbon cables, pull them straight out of their plugs. Do this gently to avoid damaging the connections.
After disconnecting both cables, pull the screen away from the camera to remove it.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
