メインコンテンツにスキップ
Canon Powershot S410 Memory Card Replacement
  1. Canon Powershot S410 Memory Card Replacement, Battery: 手順 1、 2の画像 1 Canon Powershot S410 Memory Card Replacement, Battery: 手順 1、 2の画像 2
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Canon Powershot S410 Memory Card Replacement: 手順 2、 1の画像 1
    • Pull the orange lever and the battery will spring out slightly.
  3. Canon Powershot S410 Memory Card Replacement: 手順 3、 2の画像 1 Canon Powershot S410 Memory Card Replacement: 手順 3、 2の画像 2
    • Grasp the battery and fully pull it out of its slot.
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  4. Canon Powershot S410 Memory Card Replacement, Memory Card: 手順 4、 2の画像 1 Canon Powershot S410 Memory Card Replacement, Memory Card: 手順 4、 2の画像 2
    • Position the camera as if you were going to take a picture.
    • Locate the sliding button labeled "CF OPEN."
    • Place your finger on the button and slide it in the direction of the arrow.
    • The side panel will flip open revealing the compact flash memory card.
  5. Canon Powershot S410 Memory Card Replacement: 手順 5、 1の画像 1
    • Turn the camera to the right side.
    • Locate the gray button at the bottom of the open slot.
    • Place your finger on the button and push it down.
    • The memory card will pop out slightly.
  6. Canon Powershot S410 Memory Card Replacement: 手順 6、 1の画像 1
    • Grasp edges of card and pull out of slot.
    • If you insert a new memory card you may be asked to format it after turning on the camera.
    • Make sure that the arrow on the flash card is pointed towards the direction of the slot
    • Do not force the memory card into the slot. Any signs of resistance may mean the card is improperly oriented.
終わりに
Once a new memory card has been inserted close the swinging door and you're done.
作成者
4人の作成者と共同で作成されました。
Randy Lormand
メンバー登録日: 01/23/11
349 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G27
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 29
今までの合計 2,049
