メインコンテンツにスキップ
はじめに
A simple guide for removing and replacing the memory card.
ツール
ツールは指定されていません。
パーツ
パーツは指定されていません。
  1. Turn the camera with the bottom side facing up. Locate the panel labeled "Batt. Open"
    • Turn the camera with the bottom side facing up.
    • Locate the panel labeled "Batt. Open"
    • Place your finger on the panel and slide it in the direction of the arrow.
    • The slot will swing open revealing the battery pack.
  2. Rotate the camera so that the slot is horizontal.
    • Rotate the camera so that the slot is horizontal.
    • Pull the orange lever and the battery will spring out slightly.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Grasp battery and fully pull out of slot
    • Grasp battery and fully pull out of slot
    • When placing the new battery back in the slot, the arrow on the battery must align with the arrow on the camera.
  5. Position the camera as if you were going to take a picture. Locate the sliding button labeled "CF OPEN."
    • Position the camera as if you were going to take a picture.
    • Locate the sliding button labeled "CF OPEN."
    • Place your finger on the button and slide it in the direction of the arrow.
    • The side panel will flip open revealing the compact flash memory card.
  6. Turn the camera to the right side.
    • Turn the camera to the right side.
    • Locate the gray button at the bottom of the open slot.
    • Place your finger on the button and push it down.
    • The memory card will pop out slightly.
  7. Grasp edges of card and pull out of slot.
    • Grasp edges of card and pull out of slot.
    • If you insert a new memory card you may be asked to format it after turning on the camera.
    • Make sure that the arrow on the flash card is pointed towards the direction of the slot
    • Do not force the memory card into the slot. Any signs of resistance may mean the card is improperly oriented.
まとめ
Once a new memory card has been inserted close the swinging door and you're done.
Randy Lormand
メンバー登録日: 2011年01月23日
331 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-27, Maness Winter 2011 Cal Poly, Team 11-27, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G27
4 メンバー
7のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,498
