メインコンテンツにスキップ
Canon Powershot S200 Camera lens Replacement
必要な工具と部品
  1. Canon Powershot S200 Camera lens Replacement, Battery: 手順 1、 2の画像 1 Canon Powershot S200 Camera lens Replacement, Battery: 手順 1、 2の画像 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Camera lens Replacement: 手順 2、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 2、 2の画像 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Camera lens Replacement: 手順 3、 1の画像 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Camera lens Replacement, Motherboard: 手順 4、 1の画像 1
    • Remove the lanyard.
  5. Canon Powershot S200 Camera lens Replacement: 手順 5、 1の画像 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Camera lens Replacement: 手順 6、 1の画像 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Camera lens Replacement: 手順 7、 1の画像 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Camera lens Replacement: 手順 8、 1の画像 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Camera lens Replacement: 手順 9、 1の画像 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Camera lens Replacement: 手順 10、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 10、 2の画像 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Camera lens Replacement: 手順 11、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 11、 2の画像 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Camera lens Replacement: 手順 12、 1の画像 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Camera lens Replacement: 手順 13、 1の画像 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Camera lens Replacement: 手順 14、 1の画像 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Camera lens Replacement: 手順 15、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 15、 2の画像 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Camera lens Replacement: 手順 16、 1の画像 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Camera lens Replacement: 手順 17、 1の画像 1
    • Remove the motherboard from the main frame of the camera body.
  18. Canon Powershot S200 Camera lens Replacement, Screen: 手順 18、 1の画像 1
    • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  19. Canon Powershot S200 Camera lens Replacement: 手順 19、 1の画像 1
    • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  20. Canon Powershot S200 Camera lens Replacement: 手順 20、 1の画像 1
    • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
    • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
  21. Canon Powershot S200 Camera lens Replacement: 手順 21、 1の画像 1
    • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  22. Canon Powershot S200 Camera lens Replacement: 手順 22、 1の画像 1
    • Unsolder the four points at the top of the screen with a soldering iron
    • You do not need to unsolder the screen to get to the lens, but follow the rest of the steps to free the screen from the housing plate.
  23. Canon Powershot S200 Camera lens Replacement: 手順 24、 1の画像 1
    • Remove the card-reader shield by removing the screw at the top of the shield.
  24. Canon Powershot S200 Camera lens Replacement: 手順 25、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 25、 2の画像 2
    • Remove the 2 black screws that attach the battery box to the housing plate.
    • The second picture shows the battery box detached from the housing plate.
  25. Canon Powershot S200 Camera lens Replacement: 手順 26、 1の画像 1
    • Remove the three (3.1mm) black screws that were behind the screen and battery box.
  26. Canon Powershot S200 Camera lens Replacement: 手順 27、 2の画像 1 Canon Powershot S200 Camera lens Replacement: 手順 27、 2の画像 2
    • Carefully remove the lens.
    • Remove the bottom side of the lens first before the viewfinder side.
    • Be careful of wires and delicate parts.
終わりに
作成者
3人の作成者と共同で作成されました。
Joseph Melo
メンバー登録日: 04/07/11
123 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 20-70, Walters Spring 2011 Cal Poly, Team 20-70, Walters Spring 2011人のメンバー
CPSU-WALTERS-S11S20G70
5 メンバー
4のガイドは作成済み
コメント 1 件
Camera in the pictures is not Canon Powershot S200
jkovalai - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 15
過去 30 日: 19
今までの合計 1,797
