メインコンテンツにスキップ
Canon Powershot S110 Option Dial Replacement
必要な工具と部品
  1. Canon Powershot S110 Option Dial Replacement, Option Dial: 手順 1、 2の画像 1 Canon Powershot S110 Option Dial Replacement, Option Dial: 手順 1、 2の画像 2
    • Remove the battery by sliding open the battery cover on the bottom of the camera.
    • The battery must be removed to avoid shorting out any part of the camera.
  2. Canon Powershot S110 Option Dial Replacement: 手順 2、 3の画像 1 Canon Powershot S110 Option Dial Replacement: 手順 2、 3の画像 2 Canon Powershot S110 Option Dial Replacement: 手順 2、 3の画像 3
    • Remove the six screws by using a small Phillips head screwdriver.
    • Remove the two screws on the side of the camera on either side of the HDMI input panel.
    • Remove the two screws on the opposite side of the camera.
    • Remove the two screws on the bottom of the camera located on either side of the tripod mounting hole.
  3. Canon Powershot S110 Option Dial Replacement: 手順 3、 1の画像 1
    • Using an opening tool, carefully remove the outermost cover of the camera from its holders around the edges.
    • Once all of the clips around the plastic cover are released, the cover will lift off.
  4. Canon Powershot S110 Option Dial Replacement: 手順 4、 2の画像 1 Canon Powershot S110 Option Dial Replacement: 手順 4、 2の画像 2
    • Remove the two screws holding the top plastic bracket in place by using a Phillips head screwdriver.
    • Remove the screw holding down the lens cover.
    • Remove the screw located near the option dial next to the USB connections.
  5. Canon Powershot S110 Option Dial Replacement: 手順 5、 1の画像 1
    • Carefully lift the top panel of the camera by using a prying tool.
  6. Canon Powershot S110 Option Dial Replacement: 手順 6、 1の画像 1
    • Remove the screw at the center of the option dial by using a Phillips head screwdriver.
  7. Canon Powershot S110 Option Dial Replacement: 手順 7、 2の画像 1 Canon Powershot S110 Option Dial Replacement: 手順 7、 2の画像 2
    • Remove the underlying component that was attached to the now-removed screw by using a prying tool.
    • Remove the dial on the opposite side of the part using a prying tool.
終わりに
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
akac92
メンバー登録日: 07/14/15
298 ポイント
2のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Liner SU 2015 UW Tacoma, Team 1-2, Liner SU 2015人のメンバー
UWT-LINER-SU15S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 1,176
