メインコンテンツにスキップ
Canon Powershot Pro1 Motherboard Replacement
必要な工具と部品
  1. Canon Powershot Pro1 Motherboard  Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Motherboard  Replacement: 手順 2、 1の画像 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Motherboard  Replacement: 手順 3、 1の画像 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Motherboard  Replacement: 手順 4、 1の画像 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 手順 5、 3の画像 1 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 手順 5、 3の画像 2 Canon Powershot Pro1 Motherboard  Replacement, Motherboard: 手順 5、 3の画像 3
    • Open the screen to access the underside of the camera.
  6. Canon Powershot Pro1 Motherboard  Replacement: 手順 6、 3の画像 1 Canon Powershot Pro1 Motherboard  Replacement: 手順 6、 3の画像 2 Canon Powershot Pro1 Motherboard  Replacement: 手順 6、 3の画像 3
    • Using the Phillips #000 screwdriver:
    • Remove two 1.00 mm screws under the viewfinder.
    • Remove one screw in the battery compartment.
    • Remove five screws on the bottom of the camera.
    • Remove one screw on the left side of the camera (opposite the battery compartment).
  7. Canon Powershot Pro1 Motherboard  Replacement: 手順 7、 3の画像 1 Canon Powershot Pro1 Motherboard  Replacement: 手順 7、 3の画像 2 Canon Powershot Pro1 Motherboard  Replacement: 手順 7、 3の画像 3
    • Completely detach the cover from the motherboard.
    • Lift the inside cover to reveal the motherboard.
    • Detach the bottom right ribbon cable from the motherboard.
    • Lift up the gold insulation cover to reveal the motherboard.
    • Use tweezers and an iFixit opening tool, detach any wire connectors and ribbon cables from the motherboard.
  8. Canon Powershot Pro1 Motherboard  Replacement: 手順 9、 3の画像 1 Canon Powershot Pro1 Motherboard  Replacement: 手順 9、 3の画像 2 Canon Powershot Pro1 Motherboard  Replacement: 手順 9、 3の画像 3
    • Once detached from all connectors and ribbon cables, remove the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Seana Meegan
メンバー登録日: 09/06/19
639 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G1, Bedsole Fall 2019 University of Alabama, Team S1-G1, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S1G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 22
今までの合計 643
