メインコンテンツにスキップ
Canon Powershot Pro1 Flash Replacement
必要な工具と部品
  1. Canon Powershot Pro1 Flash Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery compartment cover on the right hand side of the camera. The cover features the text: “CF/BATT.OPEN”.
  2. Canon Powershot Pro1 Flash Replacement: 手順 2、 1の画像 1
    • There is an arrow beside the text. Using your hands, slide the cover in the direction of this arrow.
  3. Canon Powershot Pro1 Flash Replacement: 手順 3、 1の画像 1
    • Pull the cover toward you. After doing so you will see the battery sitting inside the compartment.
  4. Canon Powershot Pro1 Flash Replacement: 手順 4、 1の画像 1
    • Press the orange battery lock inside the compartment.
    • Remove the battery.
    • This photo show the battery compartment after the battery has been removed.
  5. Canon Powershot Pro1 Flash Replacement, Flash: 手順 5、 2の画像 1 Canon Powershot Pro1 Flash Replacement, Flash: 手順 5、 2の画像 2
    • Remove the 25.4 mm Phillips #0 flash screw. The screw is near the flash.
    • Be careful not to damage the screw.
  6. Canon Powershot Pro1 Flash Replacement: 手順 6、 1の画像 1
    • Locate the small points on both sides of the lens.
    • Pry the lens housing using the black nylon spudger so that it is lifted out of these points.
    • Don't use a screwdriver as a prying tool, this could cause damage.
  7. Canon Powershot Pro1 Flash Replacement: 手順 7、 1の画像 1
    • Use the plastic spudger to remove the upper portion of the flash housing.
  8. Canon Powershot Pro1 Flash Replacement: 手順 8、 3の画像 1 Canon Powershot Pro1 Flash Replacement: 手順 8、 3の画像 2 Canon Powershot Pro1 Flash Replacement: 手順 8、 3の画像 3
    • Use the nylon spudger to dislodge the flash bulb and capacitor from the housing.
    • Don't use a screwdriver as prying tool, this could cause damage.
  9. Canon Powershot Pro1 Flash Replacement: 手順 9、 1の画像 1
    • Cut the flash and capacitor cables with a wire cutter.
終わりに
作成者
2人の作成者と共同で作成されました。
Seana Meegan
メンバー登録日: 09/06/19
639 ポイント
5のガイドは作成済み
チーム
University of Alabama, Team S1-G1, Bedsole Fall 2019 University of Alabama, Team S1-G1, Bedsole Fall 2019人のメンバー
UA-BEDSOLE-F19S1G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 619
