メインコンテンツにスキップ
Canon Powershot ELPH 100 HS LCD Display Replacement
必要な工具と部品
  1. Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: 手順 1、 3の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: 手順 1、 3の画像 2 Canon Powershot ELPH 100 HS LCD Display Replacement, Battery: 手順 1、 3の画像 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 2、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 2、 2の画像 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: 手順 3、 3の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: 手順 3、 3の画像 2 Canon Powershot ELPH 100 HS LCD Display Replacement, Memory Card: 手順 3、 3の画像 3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
  4. Canon Powershot ELPH 100 HS LCD Display Replacement, Outer Case: 手順 4、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the two 3.1mm screws from the bottom of the camera.
    • Keep track of all the screws that are being taken out from the outer case.
    • The display screen of the camera should be facing towards you.
  5. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 5、 1の画像 1
    • Ensure that the screen is facing you, and then rotate it till you see the screws on the side of the camera.
    • Use the Phillips #00 screwdriver to remove the two 3.1 mm screws.
  6. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 6、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 6、 2の画像 2
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  7. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 7、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 7、 2の画像 2
    • Use the Philips #00 screwdriver to pry open the charging port cover.
    • Once you pry open the charging port cover, rotate the cover so that you have access to the screw underneath. Which is seen in the next image.
    • Remove both 3.1 mm screws using the Phillips #00 screwdriver.
    • The image still shows the screw from step 3 in place.
  8. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 8、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 8、 2の画像 2
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Carefully go around all of the edges until the cover is released.
  9. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 9、 1の画像 1
    • Once the entire front cover has been released carefully pull it off.
    • Be careful not to break the tabs that hold it in place.
  10. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 10、 3の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 10、 3の画像 2 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 10、 3の画像 3
    • Just like Step 4-6 , carefully use the Spudger to remove the back cover.
    • Go along all the borders of the back cover so that it releases from the camera safely.
    • Be careful not to break the tabs.
  11. Canon Powershot ELPH 100 HS LCD Display Replacement, LCD Display: 手順 11、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement, LCD Display: 手順 11、 2の画像 2
    • Remove the 3.1mm screw on the top-right side of the LCD display screen.
  12. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 12、 1の画像 1
    • Use the spudger to carefully separate the screen from the frame.
  13. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 13、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 13、 2の画像 2
    • Use the spudger to lift up the latch on the zero insertion force connector (ZIF).
    • Slide the now free ribbon cable from the connector.
  14. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 14、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 14、 2の画像 2
    • Holding the display screen, gently pull the ribbon cable out through the frame of the camera.
  15. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 15、 2の画像 1 Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 15、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, carefully remove the ribbon cable from the connector shown.
  16. Canon Powershot ELPH 100 HS LCD Display Replacement: 手順 16、 1の画像 1
    • The display screen should now be free.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jacob
メンバー登録日: 03/17/15
570 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-10, Lauer Spring 2015 Michigan Tech, Team 1-10, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G10
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 58
今までの合計 4,044
