はじめに
Use this guide if you need to replace the viewfinder on your Canon Powershot A70
The viewfinder is an essential piece of the camera which allows you to see a preview of what's going to be photographed before you actually take a photo. Often, errors from the viewfinder come with heavy usage or simple things like not enough light in the room.
Rough treatment or regular wear and tear could also eventually either break or dislodge the viewfinder; however if the issue is something like the lens being blurry, you more than likely just have to clean it so inspect the piece before making any possible unneeded purchases.
必要な工具と部品
Open the battery compartment and remove the batteries.
Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
Remove the wrist strap.
Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
Three screws hold the viewfinder in place: two on the top and one on the lens side of the camera.
First, remove the screw in the bent corner of the viewfinder with a Phillips #00 screwdriver.
