メインコンテンツにスキップ
Canon Powershot A70 Speaker Replacement
必要な工具と部品
  1. Canon Powershot A70 Speaker Replacement, Shutter/Speaker Panel: 手順 1、 1の画像 1
    • Open the battery compartment and remove the batteries.
    • Remove the two screws that are deep in the battery compartment with a Phillips #00 screwdriver.
  2. Canon Powershot A70 Speaker Replacement: 手順 2、 2の画像 1 Canon Powershot A70 Speaker Replacement: 手順 2、 2の画像 2
    • Open the CF compartment and remove the top screw with a Phillips #00 screwdriver.
    • The panel that holds the shutter button and zoom will come off.
    • Be careful! There are two small wires connecting the speaker to the body of the camera. These are very delicate so proceed with caution. Do not remove.
  3. Canon Powershot A70 Speaker Replacement, Rear Exterior Panel: 手順 3、 1の画像 1
    • Unscrew the three small screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Remove the wrist strap.
  4. Canon Powershot A70 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the screw in the CF compartment with a Phillips #00 screwdriver.
  5. Canon Powershot A70 Speaker Replacement: 手順 5、 3の画像 1 Canon Powershot A70 Speaker Replacement: 手順 5、 3の画像 2 Canon Powershot A70 Speaker Replacement: 手順 5、 3の画像 3
    • Open the rubber Digital AV Out compartment flap.
    • Pry the battery with an opening tool.
    • Carefully pull out the battery with two fingers.
    • Remove the two screws that are now visible with a Phillips #00 screwdriver.
  6. Canon Powershot A70 Speaker Replacement: 手順 6、 2の画像 1 Canon Powershot A70 Speaker Replacement: 手順 6、 2の画像 2
    • Starting from the bottom, carefully pull the casing off.
    • The casing will now pivot at the top.
    • There are three catches that hold the back casing to the body.
    • You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
  7. Canon Powershot A70 Speaker Replacement: 手順 7、 1の画像 1
    • The interior of the camera should look like this.
  8. Canon Powershot A70 Speaker Replacement, Front Exterior Panel: 手順 8、 1の画像 1
    • Remove the two screws at the top of the battery compartment with a Phillips #00 screwdriver.
  9. Canon Powershot A70 Speaker Replacement: 手順 9、 2の画像 1 Canon Powershot A70 Speaker Replacement: 手順 9、 2の画像 2
    • With your right thumb, pull back on the tab while using your left hand to pull the face of the camera away from the body.
  10. Canon Powershot A70 Speaker Replacement, Speakers: 手順 10、 1の画像 1
    • Remove the two clearly visible screws from the control dial with a Phillips #00 screwdriver.
    • Remove the dial—it should come off easily.
  11. Canon Powershot A70 Speaker Replacement: 手順 11、 2の画像 1 Canon Powershot A70 Speaker Replacement: 手順 11、 2の画像 2
    この手順で使用する道具:
    購入する
    • With tweezers, carefully unplug the two small wires from the green plug.
    • Carefully replace the broken speaker/shutter panel with a new one.
  12. Canon Powershot A70 Speaker Replacement: 手順 12、 1の画像 1
    • The removed panel should look like this.
終わりに
ある他の人がこのガイドを完成しました。
作成者
15人の作成者と共同で作成されました。
Laura Greek
メンバー登録日: 01/25/10
28 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 14-40, Regan Winter 2010 Cal Poly, Team 14-40, Regan Winter 2010人のメンバー
CPSU-REGAN-W10S14G40
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 3,032
