Open the rubber Digital AV Out compartment flap.
Pry the battery with an opening tool.
Carefully pull out the battery with two fingers.
Remove the two screws that are now visible with a Phillips #00 screwdriver.
Starting from the bottom, carefully pull the casing off.
The casing will now pivot at the top.
There are three catches that hold the back casing to the body.
You may have to pull with some force. The rear panel will make a snapping noise when it separates from the body.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
