はじめに
You will have to get into the inside of the camera before removing the flash bulb is possible. Some soldering may be required to completely remove the flash unit from the camera.
必要な工具と部品
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
もう少しです!
終わりに
