メインコンテンツにスキップ
Canon Powershot A610 Flash Unit Replacement
必要な工具と部品
  1. Canon Powershot A610 Flash Unit Replacement, Batteries: 手順 1、 2の画像 1 Canon Powershot A610 Flash Unit Replacement, Batteries: 手順 1、 2の画像 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Canon Powershot A610 Flash Unit Replacement: 手順 2、 1の画像 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Canon Powershot A610 Flash Unit Replacement, Camera Housing: 手順 3、 3の画像 1 Canon Powershot A610 Flash Unit Replacement, Camera Housing: 手順 3、 3の画像 2 Canon Powershot A610 Flash Unit Replacement, Camera Housing: 手順 3、 3の画像 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Canon Powershot A610 Flash Unit Replacement: 手順 4、 1の画像 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Canon Powershot A610 Flash Unit Replacement: 手順 5、 1の画像 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Canon Powershot A610 Flash Unit Replacement: 手順 6、 2の画像 1 Canon Powershot A610 Flash Unit Replacement: 手順 6、 2の画像 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Canon Powershot A610 Flash Unit Replacement: 手順 7、 1の画像 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Canon Powershot A610 Flash Unit Replacement: 手順 8、 2の画像 1 Canon Powershot A610 Flash Unit Replacement: 手順 8、 2の画像 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Canon Powershot A610 Flash Unit Replacement: 手順 9、 2の画像 1 Canon Powershot A610 Flash Unit Replacement: 手順 9、 2の画像 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Canon Powershot A610 Flash Unit Replacement: 手順 10、 3の画像 1 Canon Powershot A610 Flash Unit Replacement: 手順 10、 3の画像 2 Canon Powershot A610 Flash Unit Replacement: 手順 10、 3の画像 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Canon Powershot A610 Flash Unit Replacement, Flash Unit: 手順 11、 1の画像 1
    • Remove the 3 mm screw that holds the flash unit to the camera.
  12. Canon Powershot A610 Flash Unit Replacement: 手順 12、 1の画像 1
    • Using your forefinger and thumb, pull the flash unit upward, and out of the camera.
    • The flash unit capacitor may cause electric shocks. Do not touch both metallic ends of the capacitor simultaneously.
  13. Canon Powershot A610 Flash Unit Replacement: 手順 13、 1の画像 1
    • Remove the 3 mm screw that sits on the back of the circuit board.
  14. Canon Powershot A610 Flash Unit Replacement: 手順 14、 1の画像 1
    • Unsolder the white, yellow, brown, and green wires at their soldering points.
    • Remove and replace the flash assembly.
終わりに
作成者
10人の作成者と共同で作成されました。
Matthew Ramirez
メンバー登録日: 01/20/11
625 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 11-26, Maness Winter 2011 Cal Poly, Team 11-26, Maness Winter 2011人のメンバー
CPSU-MANESS-W11S11G26
3 メンバー
9のガイドは作成済み
コメント 1 件
Where is loccated the CMOS Battery?
Belkis Orozco - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 5,492
