メインコンテンツにスキップ
Canon PowerShot SX620 HS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SX620 HS LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Open the battery door located on the bottom of the camera.
    • Push the orange tab until the battery springs upwards and out.
    • Remove the battery from the camera.
  2. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 2、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove the two 4 mm screws from the side of the camera with the flash assembly using a Phillips #000 screwdriver
    • Make sure to keep your screws from different steps separate.
  3. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 3、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 3、 2の画像 2
    • Remove the four 2 mm screws from the bottom of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 4、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 4、 2の画像 2
    • Remove the single 4 mm screw from the other side of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 5、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 5、 2の画像 2
    • Open the HDMI cover.
    • Remove the single 4 mm screw inside the HDMI cover using a Phillips #000 screwdriver.
  6. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 6、 3の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 6、 3の画像 2 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 6、 3の画像 3
    • Use a plastic opening tool at the top of the camera to loosen the back piece of the outer case. Once it is loose, pull it straight out.
    • Use the same technique to remove the front piece of the camera case.
  7. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 7、 3の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 7、 3の画像 2 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 7、 3の画像 3
    • Place the camera with the LCD screen facing up.
    • Pull the side cover pieces out.
  8. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 8、 1の画像 1
    • Flip the camera over so the lens is facing upwards.
    • Use the Phillips #000 screwdriver to remove the screw located near the photo button.
  9. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Detach the orange connector from the lens piece using tweezers.
    • Be extremely careful with any of these connectors. They are very fragile and contain important electronic components. If one is damaged, your camera will not work at all.
  10. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 10、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 10、 2の画像 2
    • Grab the top cover piece directly above the lens. Pull upward to remove it from the camera body.
  11. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 11、 2の画像 2
    • Use the Phillips #000 screwdriver to remove the two 2 mm screws from the button panel.
  12. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 12、 3の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 12、 3の画像 2 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 12、 3の画像 3
    • Use tweezers to carefully detach the connector that is hidden underneath the button panel.
    • Be careful not to damage anything on the motherboard underneath.
    • Flip the button panel upward.
  13. Canon PowerShot SX620 HS LCD Screen Replacement: 手順 13、 3の画像 1 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 13、 3の画像 2 Canon PowerShot SX620 HS LCD Screen Replacement: 手順 13、 3の画像 3
    • Flip the small black cover upward so you can remove the large orange connector. Carefully remove this connector and the smaller connector holding the LCD screen in place.
    • Lift the LCD screen out of the metal frame.
終わりに
作成者
2人の作成者と共同で作成されました。
Karl Loechelt
メンバー登録日: 09/08/21
267 ポイント
1ガイドが承認済み
チーム
1件のガイドコメント
How did you reattach the button panel connector once you had flipped it back down?
beep - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 98
今までの合計 3,127
