メインコンテンツにスキップ
Canon PowerShot SX600 HS Power and Shutter Buttons Replacement
必要な工具と部品
  1. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Battery: 手順 1、 1の画像 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 2、 1の画像 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 3、 2の画像 1 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 3、 2の画像 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
  4. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement, Power and Shutter Buttons: 手順 4、 1の画像 1
    • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
  5. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 5、 1の画像 1
    • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
  6. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 6、 1の画像 1
    • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
  7. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 7、 2の画像 1 Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 7、 2の画像 2
    • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
  8. Canon PowerShot SX600 HS Power and Shutter Buttons Replacement: 手順 8、 1の画像 1
    • Use an opening tool to gently remove the power and shutter button assembly from the frame.
終わりに
作成者
2人の作成者と共同で作成されました。
Jennyfer Munoz
メンバー登録日: 02/15/17
411 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S6-G4, Lacy Spring 2017 USF Tampa, Team S6-G4, Lacy Spring 2017人のメンバー
USFT-LACY-S17S6G4
3 メンバー
9のガイドは作成済み
3 Guide Comments
Where does one buy an “opening tool”?
Evelyn Vose - 返信
Where does one buy an “opening tool?”
Evelyn Vose - 返信
Hello Evelyn,
you can buy it in the ifixit store. Otherwise you can use a plastic card you don’t need any more (it will be scratched and or bend afterwards, so you probably better don take a creditcard).
John Maier - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 834
