メインコンテンツにスキップ
Canon PowerShot SX60 HS Viewfinder Replacement
必要な工具と部品
  1. Canon PowerShot SX60 HS Viewfinder Replacement, Back Panel: 手順 1、 1の画像 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Viewfinder Replacement: 手順 2、 2の画像 1 Canon PowerShot SX60 HS Viewfinder Replacement: 手順 2、 2の画像 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Viewfinder Replacement: 手順 3、 2の画像 1 Canon PowerShot SX60 HS Viewfinder Replacement: 手順 3、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Viewfinder Replacement: 手順 4、 2の画像 1 Canon PowerShot SX60 HS Viewfinder Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: 手順 5、 2の画像 1 Canon PowerShot SX60 HS Viewfinder Replacement, Viewfinder: 手順 5、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the two 2mm #00 silver screws located under the viewfinder.
    • Don't pull the viewfinder all the way out because there is still a wire ribbon attached.
    • Remove the plastic housing around the viewfinder by using a black spudger or opening tool to unclip the 3 plastic clips on the sides of the viewfinder.
  6. Canon PowerShot SX60 HS Viewfinder Replacement: 手順 6、 2の画像 1 Canon PowerShot SX60 HS Viewfinder Replacement: 手順 6、 2の画像 2
    • Unclip the ribbon from the ZIF connector on the viewfinder.
    • Pull out the viewfinder.
終わりに
作成者
4人の作成者と共同で作成されました。
Ethan Boone
メンバー登録日: 07/08/19
803 ポイント
7のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 18
今までの合計 749
