メインコンテンツにスキップ
Canon PowerShot SX60 HS Front Panel Replacement
必要な工具と部品
  1. Canon PowerShot SX60 HS Front Panel Replacement, Back Panel: 手順 1、 1の画像 1
    • Make sure to power off the device before completing any more steps.
    • Remove the battery by releasing the orange clip in the battery compartment.
  2. Canon PowerShot SX60 HS Front Panel Replacement: 手順 2、 2の画像 1 Canon PowerShot SX60 HS Front Panel Replacement: 手順 2、 2の画像 2
    • Remove the rubber eye piece by pulling it back.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
  3. Canon PowerShot SX60 HS Front Panel Replacement: 手順 3、 2の画像 1 Canon PowerShot SX60 HS Front Panel Replacement: 手順 3、 2の画像 2
    • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
    • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
    • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
    • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
  4. Canon PowerShot SX60 HS Front Panel Replacement: 手順 4、 2の画像 1 Canon PowerShot SX60 HS Front Panel Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Ensure the LCD screen is swung fully to the left before taking off the back panel.
    • Use the iFixit opening tool to pry off the back panel.
    • Don't completely pull off the back panel because there is still a ribbon attached.
    • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
    • Once the ribbon is unplugged, remove the back panel from the camera body.
  5. Canon PowerShot SX60 HS Front Panel Replacement, Front Panel: 手順 5、 2の画像 1 Canon PowerShot SX60 HS Front Panel Replacement, Front Panel: 手順 5、 2の画像 2
    • Remove the sunshade located on the front of the lens by twisting it 90 degrees in either direction, then pull straight off the lens.
  6. Canon PowerShot SX60 HS Front Panel Replacement: 手順 6、 3の画像 1 Canon PowerShot SX60 HS Front Panel Replacement: 手順 6、 3の画像 2 Canon PowerShot SX60 HS Front Panel Replacement: 手順 6、 3の画像 3
    • Remove the 5mm Phillips #00 screw located on the left side below the microphone connection.
    • Remove the 4mm Phillips #00 screw located on the bottom left of the camera.
    • Remove the 5mm Phillips #00 screw located on the bottom center of the camera.
    • Pop open the flash and remove the 5mm Phillips #00 screw located under the flash.
  7. Canon PowerShot SX60 HS Front Panel Replacement: 手順 7、 1の画像 1
    • Remove the front cover by pulling along the lens housing while holding the body of the camera.
終わりに
作成者
4人の作成者と共同で作成されました。
Ethan Boone
メンバー登録日: 07/08/19
803 ポイント
7のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 9
今までの合計 399
