メインコンテンツにスキップ
Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement
必要な工具と部品
  1. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Battery: 手順 1、 1の画像 1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
  2. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 2、 1の画像 1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
  3. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Canon PowerShot SX530 HS Back Panel Assembly: 手順 3、 2の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Canon PowerShot SX530 HS Back Panel Assembly: 手順 3、 2の画像 2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
  4. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 4、 2の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 4、 2の画像 2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
  5. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 5、 2の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 5、 2の画像 2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
  6. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 6、 3の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 6、 3の画像 2 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 6、 3の画像 3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
  7. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Internal Button Sensor Plate: 手順 7、 2の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement, Internal Button Sensor Plate: 手順 7、 2の画像 2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
  8. Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 8、 2の画像 1 Canon PowerShot SX530 HS Internal Button Sensor Plate Replacement: 手順 8、 2の画像 2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Xavier Patrick
メンバー登録日: 02/02/17
481 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 16-4, Blackwell Spring 2017 USF Tampa, Team 16-4, Blackwell Spring 2017人のメンバー
USFT-BLACKWELL-S17S16G4
4 メンバー
9のガイドは作成済み
コメント 1 件
Przy najkrótszych śrubkach jest problem zich wyjęciem z otworu. POtrzebny śrubokręt z namagnesowanym czubkiem.
Ryszard Lasocki - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 18
今までの合計 912
