メインコンテンツにスキップ
Canon PowerShot SX520 HS Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot SX520 HS Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Using your fingers, slide the battery compartment door to the right until it unlocks.
  2. Canon PowerShot SX520 HS Motherboard Replacement: 手順 2、 1の画像 1
    • Rotate the door along hinges to open.
    • Take out the battery with your fingers.
  3. Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 手順 3、 3の画像 1 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 手順 3、 3の画像 2 Canon PowerShot SX520 HS Motherboard Replacement, Back Face: 手順 3、 3の画像 3
    • Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
  4. Canon PowerShot SX520 HS Motherboard Replacement: 手順 4、 1の画像 1
    • Remove 2-4 mm screws that secure the bottom of the camera using a Phillips #000 screwdriver.
  5. Canon PowerShot SX520 HS Motherboard Replacement: 手順 5、 2の画像 1 Canon PowerShot SX520 HS Motherboard Replacement: 手順 5、 2の画像 2
    • Pull back the rubber facing to access the A/V and HDMI output compartment.
    • Remove 1-3.4mm screw inside the compartment using a Phillips #000 screwdriver.
  6. Canon PowerShot SX520 HS Motherboard Replacement: 手順 6、 1の画像 1
    • Once all screws are removed, pull the back facing off with your fingers.
  7. Canon PowerShot SX520 HS Motherboard Replacement, LCD Screen: 手順 7、 1の画像 1
    • Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
  8. Canon PowerShot SX520 HS Motherboard Replacement: 手順 8、 1の画像 1
    • Carefully pop out the LCD screen with your fingers.
  9. Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 手順 9、 3の画像 1 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 手順 9、 3の画像 2 Canon PowerShot SX520 HS Motherboard Replacement, Metal Plate: 手順 9、 3の画像 3
    • Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
    • Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
    • After all 8 screws are removed, pull the metal plate out with your fingers.
  10. Canon PowerShot SX520 HS Motherboard Replacement, Lens: 手順 10、 1の画像 1
    • Unlcip the large cable by pulling up on the metal part with your finger.
    • Slide out the 2 smaller cables with your fingers.
  11. Canon PowerShot SX520 HS Motherboard Replacement: 手順 11、 1の画像 1
    • Lift up the lens by grabbing the sides with your fingers.
  12. Canon PowerShot SX520 HS Motherboard Replacement, Motherboard: 手順 12、 1の画像 1
    • Remove 1-2.5 mm screw using a Phillips #000 screwdriver.
  13. Canon PowerShot SX520 HS Motherboard Replacement: 手順 13、 2の画像 1 Canon PowerShot SX520 HS Motherboard Replacement: 手順 13、 2の画像 2
    • Disconnect the two orange serial cables at the top of the motherboard using your fingers.
    • Gently remove the motherboard using your fingers.
    • Too much force will break the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Kyle Crowley
メンバー登録日: 09/22/15
337 ポイント
3のガイドは作成済み
チーム
Baylor, Team 4-4, Williams Fall 2015 Baylor, Team 4-4, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S4G4
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 1,003
