はじめに
If you crack the lens of your camera or if it is not functioning properly, this guide may be for you. This guide will help you remove and replace the lens.
必要な工具と部品
Using your fingers, slide the battery compartment door to the right until it unlocks.
Remove 2-3.4 mm screws that secure the back panel using a Phillips #000 screwdriver.
Remove 4-4 mm screws on the left and right sides of the camera using a Phillips #000 screwdriver.
Remove 3-4.4 mm screws that secure the small metal plate using a Phillips #000 screwdriver.
Remove 6-4.4 mm screws that secure the metal cover using a Phillips #000 screwdriver.
Remove 2-2.5 mm screws that secure the back panel using a Phillips #000 screwdriver.
After all 8 screws are removed, pull the metal plate out with your fingers.
Lift up the lens by grabbing the sides with your fingers.
Como consigo más sesiones completas estoy en limpieza de mi cámara canon powershot sx 520 hs que se me cayó en una posa sucia y necesito desarmarla por completa para limpiarla y me gustaría conseguir un manual completo para desarmarla y armarla de nuevo gracias / la cámara estaba apagada al lograrla sacar le quite la batería para que no sufriera ningún daño
6 の人々がこのガイドを完成させました。
1 Guide Comment
guide is unfinished; dropping to the point of lens group extraction without going on further. I found it, useless.
