メインコンテンツにスキップ
Canon PowerShot SX260 HS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 1 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 2 Canon PowerShot SX260 HS LCD Screen Replacement, LCD Screen: 手順 1、 3の画像 3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 (3 mm) screws on the left side
    • Remove the 2 (3 mm) screws on the bottom of the camera.
    • Remove the 2 (3 mm) screws on the right side of the camera.
  2. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 2、 1の画像 1
    • Use your plastic opening tool to gently lift and remove back face plate.
    • Unplug the ribbon cable leading to the mode dial.
  3. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 3、 1の画像 1
    • After removing exterior screws, gently lift off the front face plate with your fingers.
  4. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the 4 (3 mm) screws that are under the face plate.
  5. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 5、 1の画像 1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  6. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 6、 1の画像 1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  7. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 7、 1の画像 1
    • Next,take off the 2 (3mm) screws on the back side of the camera to remove the dial panel.
    • Gently lift the panel with your fingers.
    • Be careful not to rip the attached yellow ribbon cable.
  8. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Carefully unplug the yellow ribbon cable from the front of the camera using your tweezers.
  9. Canon PowerShot SX260 HS LCD Screen Replacement: 手順 9、 1の画像 1
    • Gently slide the LCD screen to the right and remove.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tyler Kelch
メンバー登録日: 03/05/15
622 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team 11-8, Blackburne Winter 2015 Sam Houston State, Team 11-8, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G8
2 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 138
今までの合計 4,085
