メインコンテンツにスキップ
Canon PowerShot SX260 HS Flash Assembly Replacement
必要な工具と部品
  1. Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 1 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 2 Canon PowerShot SX260 HS Flash Assembly Replacement, Flash Assembly: 手順 1、 3の画像 3
    • Be sure to always remove the battery from the camera before disassembling to avoid permanent damage.
    • The camera has a total of 6 (3 mm) external screws that will need to be removed; 2 on the left side, 2 on the bottom, and 2 on the right side.
    • Remove the 2 screws on the left side.
    • Remove the 2 screws on the bottom of the camera.
    • Remove the 2 screws on the right side of the camera.
  2. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 2、 1の画像 1
    • Use your plastic opening tool to gently lift and remove the back face plate.
  3. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 3、 1の画像 1
    • After removing the exterior screws, use your fingers to gently lift off the front face plate.
  4. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 4、 1の画像 1
    • Next, remove the 2 (3 mm) interior screws on the left side of the camera.
  5. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 5、 1の画像 1
    • After removing the interior left screws, use a plastic opening tool to gently pull the top face plate off.
  6. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 6、 1の画像 1
    • Next, you will need to remove the dial panel by removing the 2 (3mm) screws on the back side of the camera.
    • Gently remove the dial panel with your fingers.
  7. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 7、 2の画像 1 Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 7、 2の画像 2
    • Remove 1 (3 mm) screw from the flash generator with a Phillips screw driver
    • Gently lift the flash generator off of the camera with the plastic opening tool .
  8. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Gently unplug the ribbon cable with your tweezers.
    • Be careful not to rip it.
  9. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 9、 2の画像 1 Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 9、 2の画像 2
    • Using your plastic opening tool to gently move the plug lock from the end of the ribbon cord by lifting it upward.
    • Gently remove the ribbon cable from the connector with tweezers.
  10. Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 10、 2の画像 1 Canon PowerShot SX260 HS Flash Assembly Replacement: 手順 10、 2の画像 2
    • Gently remove the ribbon cable assembly from the top of the camera with your tweezers.
    • This cable is a long piece that runs across the top of the camera.
    • The flash assembly is connected to this cable.
    • Once removed gently lift out of the camera
    • Replace the ribbon cable with the attached flash assembly.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Tyler Kelch
メンバー登録日: 03/05/15
622 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team 11-8, Blackburne Winter 2015 Sam Houston State, Team 11-8, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S11G8
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 14
過去 30 日: 51
今までの合計 1,894
