はじめに
This guide walks you through how to replace a shutter button on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
必要な工具と部品
Unscrew 2-4.8mm black screws from the front of the camera using a #0 Phillips screwdriver.
Unscrew 2-4.8mm black screws from the side of the camera using a #0 Phillips screwdriver.
Unscrew 2-4.8mm black screws from the bottom of the camera using a #0 Phillips screwdriver.
Congratulations, you have successfully replaced your shutter button. To reassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
Not all of these screws are 4.8mm. There are additional screws that need to be removed as well, including a third one on the bottom, and a hidden one on the upper left after the back cover has been removed. Common sense will tell you which ones need to come out. There are also in the flash basin that need to be removed.
Will Chamberlain - 返信
