メインコンテンツにスキップ
Canon PowerShot SX160 IS Clock Battery Replacement
必要な工具と部品
  1. Canon PowerShot SX160 IS Clock Battery Replacement, Clock Battery: 手順 1、 1の画像 1
    • Locate the internal battery tray on the side of your camera.
    Thank you so much for your help. I was able to fix it without any problems.
    Barbara - 返信
    Your instructions to replace the battery was most helpful. Thank you.
    Barbara - 返信
  2. Canon PowerShot SX160 IS Clock Battery Replacement: 手順 2、 1の画像 1
    • Use your finger or a spudger to gently pry the battery tray out of the camera.
  3. Canon PowerShot SX160 IS Clock Battery Replacement: 手順 3、 1の画像 1
    • Fully remove the battery tray from the camera.
  4. Canon PowerShot SX160 IS Clock Battery Replacement: 手順 4、 1の画像 1
    • Remove battery from tray and replace.
    These photos show the battery upside-down. The positive goes down, towards the plastic tray, while the negative goes up, towards the open top of the tray.
    tomcatanzaro - 返信
    Thanks, Tom! I first put the battery in the way the photo displayed, and then set the date. When I turned the camera off, then on again, I got the message the date and time needed to be set. Changing to your way solved my problem! Thanks so much!!
    William Burke -
    Where can I buy batteries like these? Thanks
    Nicole - 返信
終わりに
Congratulations, you have successfully replaced the internal battery. To reassemble your device, follow these instructions in reverse order.
36 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jamie Secretan
メンバー登録日: 03/11/15
1,962 ポイント
6のガイドは作成済み
チーム
Colorado Springs, Team 2-3, Panko Spring 2015 Colorado Springs, Team 2-3, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G3
3 メンバー
6のガイドは作成済み
17 件のコメント
Clear and simple. Thanks!
Jim - 返信
I had no idea! Thanks!
natorbett - 返信
Its not necessary to unscrew the tray.
Afzal Pawaskar - 返信
Thank you, Jamie!
Casey Cain - 返信
Gee I thought I am so glad I checked the Internet first...(before I threw it in the trash) that is how frustrating this was. Thank you everyone, I do love this camera
Barbara Rivers - 返信
thank you, i couldn't find it in the manual
ramar - 返信
Best camera I've ever had yet. All I have to do now is find a supplier for the battery.
carverdoone - 返信
My sentiments exactly like Barb Rivers. It's great to have someone like you guys do such a pro. job.
Many thanks and keep up the good work.
Richard Lange - 返信
Where do I go to buy this battery?
Louise Gladkowski - 返信
Love the canon camera I have this one, but it drains batteries when taking pictures? I have to bring a 8 pack of batteries it’s crazy!
Bonnie Bennett - 返信
I have a canon camera love it but it drains batteries have to bring a 8 pack something not right? Please let me know if it’s fixable or get a different one? Thanks
Bonnie Bennett - 返信
Tried for 2 days to get in touch with Canon with no response, Jaime solved it in seconds !
Drew - 返信
The pictures are wrong, the (+) and (-) are switched. Read the battery holder, that’s ok. Eze
adreze - 返信
i put new batterry to take shot still it showing low battery what will be the problem
montu bhagat - 返信
hi. direction easy, but still have problem
Suzanne LaCroix - 返信
got the battery out ok. now where the !&&* do i get a new one? no one carries it around my neck of the woods….
suesan629 - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 62
過去 30 日: 300
今までの合計 47,302
