メインコンテンツにスキップ
Canon PowerShot SX150 IS Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot SX150 IS Motherboard Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 1 Canon PowerShot SX150 IS Motherboard Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 2 Canon PowerShot SX150 IS Motherboard Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Motherboard Replacement, Canon PowerShot SX150 IS Prerequisite: 手順 2、 1の画像 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Canon PowerShot SX150 IS Motherboard Replacement: 手順 3、 2の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 3、 2の画像 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Canon PowerShot SX150 IS Motherboard Replacement: 手順 4、 1の画像 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Canon PowerShot SX150 IS Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the plastic panel surrounding the back screen.
  6. Canon PowerShot SX150 IS Motherboard Replacement: 手順 6、 3の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 6、 3の画像 2 Canon PowerShot SX150 IS Motherboard Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  7. Canon PowerShot SX150 IS Motherboard Replacement: 手順 7、 2の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 7、 2の画像 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  8. Canon PowerShot SX150 IS Motherboard Replacement: 手順 8、 1の画像 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  9. Canon PowerShot SX150 IS Motherboard Replacement: 手順 9、 3の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 9、 3の画像 2 Canon PowerShot SX150 IS Motherboard Replacement: 手順 9、 3の画像 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  10. Canon PowerShot SX150 IS Motherboard Replacement: 手順 10、 2の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 10、 2の画像 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  11. Canon PowerShot SX150 IS Motherboard Replacement: 手順 11、 3の画像 1 Canon PowerShot SX150 IS Motherboard Replacement: 手順 11、 3の画像 2 Canon PowerShot SX150 IS Motherboard Replacement: 手順 11、 3の画像 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  12. Canon PowerShot SX150 IS Motherboard Replacement, Circuit Board/Motherboard Removal: 手順 12、 3の画像 1 Canon PowerShot SX150 IS Motherboard Replacement, Circuit Board/Motherboard Removal: 手順 12、 3の画像 2 Canon PowerShot SX150 IS Motherboard Replacement, Circuit Board/Motherboard Removal: 手順 12、 3の画像 3
    この手順で使用する道具:
    • The green-colored circuit board is connected to the camera with a total of four flex ribbons.
    • The three flex ribbons on the right have locking latches that need to be unlatched before removing flex ribbons. Unlatch all three latches and then remove flex ribbons using tweezers.
    • The fourth flex ribbon needs to be carefully unplugged using tweezers.
    • Once all four flex ribbons are unplugged the green motherboard is free for removal.
終わりに
作成者
4人の作成者と共同で作成されました。
Sam Blanton
メンバー登録日: 09/12/16
461 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Fall 2016 Western Carolina University, Team 1-1, Virtue Fall 2016人のメンバー
WCU-VIRTUE-F16S1G1
4 メンバー
7のガイドは作成済み
コメント 1 件
This procedure is bogus. It's more or less ok until the last step: "Once all four flex ribbons are unplugged the green motherboard is free for removal." WRONG! The mainboard is still connected to the battery case, flash module and cmos battery with wires soldered to it. Good luck with that unless you're an expert solderer. I got sucked in thinking I could swap the mainboard from a for-parts sx150is into one with a flakey USB port. Waste of time.
Sidney Tupper - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 16
過去 30 日: 32
今までの合計 1,021
