はじめに
This guide will guide you through replacing the motherboard/ circuit board in your Canon Powershot SX150 IS. This will help you fix any major issues with the camera function, if there seems to be no problems with the other hardware.
必要な工具と部品
Locate the battery cover on the bottom of the camera.
Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
Remove batteries.
Remove the two 2mm screws above the screen using the size J000 screwdriver.
The green-colored circuit board is connected to the camera with a total of four flex ribbons.
The three flex ribbons on the right have locking latches that need to be unlatched before removing flex ribbons. Unlatch all three latches and then remove flex ribbons using tweezers.
The fourth flex ribbon needs to be carefully unplugged using tweezers.
Once all four flex ribbons are unplugged the green motherboard is free for removal.
コメント 1 件
This procedure is bogus. It's more or less ok until the last step: "Once all four flex ribbons are unplugged the green motherboard is free for removal." WRONG! The mainboard is still connected to the battery case, flash module and cmos battery with wires soldered to it. Good luck with that unless you're an expert solderer. I got sucked in thinking I could swap the mainboard from a for-parts sx150is into one with a flakey USB port. Waste of time.
