メインコンテンツにスキップ
Canon PowerShot SX150 IS Lens Replacement
必要な工具と部品
  1. Canon PowerShot SX150 IS Lens Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement, Canon PowerShot SX150 IS Battery Removal: 手順 1、 3の画像 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Lens Replacement, Canon PowerShot SX150 IS Prerequisite: 手順 2、 1の画像 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Canon PowerShot SX150 IS Lens Replacement: 手順 3、 2の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 3、 2の画像 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Canon PowerShot SX150 IS Lens Replacement: 手順 4、 1の画像 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Canon PowerShot SX150 IS Lens Replacement: 手順 5、 1の画像 1
    • Remove the plastic panel surrounding the back screen.
  6. Canon PowerShot SX150 IS Lens Replacement: 手順 6、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 6、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement: 手順 6、 3の画像 3
    この手順で使用する道具:
    購入する
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  7. Canon PowerShot SX150 IS Lens Replacement: 手順 7、 2の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 7、 2の画像 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  8. Canon PowerShot SX150 IS Lens Replacement: 手順 8、 1の画像 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  9. Canon PowerShot SX150 IS Lens Replacement: 手順 9、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 9、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement: 手順 9、 3の画像 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  10. Canon PowerShot SX150 IS Lens Replacement: 手順 10、 2の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 10、 2の画像 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  11. Canon PowerShot SX150 IS Lens Replacement: 手順 11、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 11、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement: 手順 11、 3の画像 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  12. Canon PowerShot SX150 IS Lens Replacement, Lens: 手順 12、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement, Lens: 手順 12、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement, Lens: 手順 12、 3の画像 3
    この手順で使用する道具:
    購入する
    • First, very carefully open the latch on each of the three flex ribbons (two black, one brown).
    • With tweezers, very carefully detach all three flex ribbons from their ports.
    • Carefully detach the flex ribbon from the side.
  13. Canon PowerShot SX150 IS Lens Replacement: 手順 13、 3の画像 1 Canon PowerShot SX150 IS Lens Replacement: 手順 13、 3の画像 2 Canon PowerShot SX150 IS Lens Replacement: 手順 13、 3の画像 3
    • The lens is now fully detached and can be replaced.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Madison King
メンバー登録日: 09/12/16
322 ポイント
2のガイドは作成済み
チーム
Western Carolina University, Team 1-1, Virtue Fall 2016 Western Carolina University, Team 1-1, Virtue Fall 2016人のメンバー
WCU-VIRTUE-F16S1G1
4 メンバー
7のガイドは作成済み
コメント 1 件
This Guide also works well for the Canon Powershot SX130IS camera, but with just a few minor differences.
Qrash - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 2,443
