メインコンテンツにスキップ
Canon PowerShot SX120 IS Control Dial Replacement
必要な工具と部品
  1. Canon PowerShot SX120 IS Control Dial Replacement, Back Cover: 手順 1、 1の画像 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Control Dial Replacement: 手順 2、 1の画像 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Control Dial Replacement: 手順 3、 2の画像 1 Canon PowerShot SX120 IS Control Dial Replacement: 手順 3、 2の画像 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Control Dial Replacement: 手順 4、 2の画像 1 Canon PowerShot SX120 IS Control Dial Replacement: 手順 4、 2の画像 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Control Dial Replacement: 手順 5、 1の画像 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Control Dial Replacement: 手順 6、 3の画像 1 Canon PowerShot SX120 IS Control Dial Replacement: 手順 6、 3の画像 2 Canon PowerShot SX120 IS Control Dial Replacement: 手順 6、 3の画像 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Control Dial Replacement: 手順 7、 1の画像 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
  8. Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 手順 8、 3の画像 1 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 手順 8、 3の画像 2 Canon PowerShot SX120 IS Control Dial Replacement, Control Dial: 手順 8、 3の画像 3
    この手順で使用する道具:
    購入する
    • Carefully remove the pin underneath the dial using a pair of tweezers and set it aside.
    • Use a pair of tweezers to remove the old control dial and set the new control in the same place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
10人の作成者と共同で作成されました。
Destiny Bretado
メンバー登録日: 03/20/14
122 ポイント
1ガイドが承認済み
チーム
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G3
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 16
今までの合計 1,351
