メインコンテンツにスキップ
Canon PowerShot SX120 IS Back Cover Replacement
必要な工具と部品
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: 手順 1、 1の画像 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: 手順 2、 1の画像 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: 手順 3、 2の画像 1 Canon PowerShot SX120 IS Back Cover Replacement: 手順 3、 2の画像 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: 手順 4、 2の画像 1 Canon PowerShot SX120 IS Back Cover Replacement: 手順 4、 2の画像 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: 手順 5、 1の画像 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: 手順 6、 3の画像 1 Canon PowerShot SX120 IS Back Cover Replacement: 手順 6、 3の画像 2 Canon PowerShot SX120 IS Back Cover Replacement: 手順 6、 3の画像 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: 手順 7、 1の画像 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Maria
メンバー登録日: 03/13/14
875 ポイント
1ガイドが承認済み
チーム
New Mexico State, Team 1-3, Easley Spring 2014 New Mexico State, Team 1-3, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G3
4 メンバー
4のガイドは作成済み
コメント 1 件
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 1,699
