メインコンテンツにスキップ
Canon PowerShot SD960 IS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SD960 IS LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 2、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 2、 2の画像 2
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 3、 1の画像 1
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
  4. Canon PowerShot SD960 IS LCD Screen Replacement, LCD Screen: 手順 4、 1の画像 1
    • Working on your electronic device while it is powered on can result in electric shock. Power off, unplug, and remove the battery of your device before continuing.
    • Close the battery door, and turn the camera over so that the bottom of the camera is facing up.
    • Using a PH000 screwdriver, remove the two 5.5mm screws.
  5. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 5、 1の画像 1
    • Turn the camera over to the side
    • Remove the two 4mm PH000 screws from the side of the camera.
  6. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 6、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 6、 2の画像 2
    • Turn camera over to the data port side with the panel that reads A/V Out.
    • Lift open the latch that covers the camera's data ports.
    • Remove the one 2.4mm PH000 screw on the left.
    • Remove the one 4mm PH000 screw on the right.
  7. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 7、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 7、 2の画像 2
    • Turn the camera over so the lens is facing up.
    • Remove the front cover.
  8. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 8、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 8、 2の画像 2
    • Turn the camera over so that the screen is facing up.
    • Remove the back cover.
  9. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 9、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 9、 2の画像 2
    • Remove two 2.4mm PH000 screws from the plate on the front of camera.
    • Gently remove the plate.
  10. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 10、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 10、 2の画像 2
    • Turn the camera over to the data port side again.
    • After removing the front panel in the previous step, the AV/OUT panel should be free to remove. Gently slide out the A/V panel.
  11. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 11、 2の画像 2
    • Turn the camera over so the top panel that reads "Image Stabilizer" is facing up.
    • Remove the two 2.4mm PH000 screws from the top of the camera to the left of the power on/off switch.
    • Gently remove the panel from the side of the camera.
  12. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 12、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 12、 2の画像 2
    • Turn the camera over so the screen is facing up.
    • Remove one 3.2mm PH000 screw from the top of the LCD screen.
    • Remove one 3.2mm PH000 screw from the bottom of the LCD screen.
  13. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 13、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 13、 2の画像 2
    • When you remove the top panel it will remain attached by a small orange cable. You can leave the cable attached; it will not obstruct you from completing the following steps.
    • Gently remove the top panel.
  14. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 14、 1の画像 1
    • Remove two 3.2mm PH000 screws on the side of the camera, to the right of the button that reads "Func. Set."
  15. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 15、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 15、 2の画像 2
    • Use a nylon spudger to flip open the teeth holding the small, orange data cable in place.
    • Gently remove the small, orange data cable. The cable should now hang free.
  16. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 16、 1の画像 1
    • Once the data cable is removed, the panel to the right of the LCD screen with the button that reads "Func. Set" will be free to remove.
    • Gently remove the panel to the right of the LCD screen.
  17. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 17、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 17、 2の画像 2
    • Locate the large, yellow data cable by turning the camera over so the lens is facing up.
    • Find where the data cable connects on the front of the camera.
  18. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 18、 2の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 18、 2の画像 2
    • Use a nylon spudger to flip open the teeth that are holding the large, yellow data cable in place.
    • Gently remove the data cable.
  19. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 19、 3の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 19、 3の画像 2 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 19、 3の画像 3
    • Remove the LCD screen.
  20. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 20、 3の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 20、 3の画像 2 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 20、 3の画像 3
    • To remove the casing around the LCD screen, begin by removing the top of the casing (which is in two pieces). First, remove the small hinge on the right side.
    • Then, remove the rest of the casing.
    • The top of the LCD screen casing should now be removed.
  21. Canon PowerShot SD960 IS LCD Screen Replacement: 手順 21、 3の画像 1 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 21、 3の画像 2 Canon PowerShot SD960 IS LCD Screen Replacement: 手順 21、 3の画像 3
    • Carefully slide out the LCD screen from the back part of the casing.
    • You should now have three components: The back of the LCD screen casing, the LCD screen, and the front of the LCD screen casing.
    • The LCD screen is now removed and can be replaced or set aside to access other camera components.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Kacy Ewing
メンバー登録日: 09/15/16
253 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-4, Campbell Fall 2016 University of North Texas, Team 1-4, Campbell Fall 2016人のメンバー
UNT-CAMPBELL-F16S1G4
2 メンバー
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,174
