メインコンテンツにスキップ
Canon PowerShot SD870 IS Flash Assembly Replacement
必要な工具と部品
  1. Canon PowerShot SD870 IS Flash Assembly Replacement, Outer Case: 手順 1、 1の画像 1
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 2、 3の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 2、 3の画像 2 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 2、 3の画像 3
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 3、 1の画像 1
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 4、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 4、 2の画像 2
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 5、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 5、 2の画像 2
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 6、 1の画像 1
    • Slide the back casing off.
  7. Canon PowerShot SD870 IS Flash Assembly Replacement, LCD: 手順 7、 1の画像 1
    • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
  8. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 8、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 8、 2の画像 2
    • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
    • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
  9. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 9、 1の画像 1
    • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    • The LCD should still be connected by the backlight cable.
  10. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 10、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 10、 2の画像 2
    • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen should now be fully detached from the camera body.
  11. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 11、 1の画像 1
    • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
    • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
  12. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 12、 1の画像 1
    • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Canon PowerShot SD870 IS Flash Assembly Replacement, Shutter Release Button: 手順 13、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement, Shutter Release Button: 手順 13、 2の画像 2
    • With the case and LCD screen removed, you are ready to remove the release button.
    • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  14. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 14、 1の画像 1
    • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
    • Remove the connector from the logic board and detach the release button housing from the camera.
  15. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 15、 2の画像 1 Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 15、 2の画像 2
    • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
    • The release button can now be removed and fixed or replaced.
  16. Canon PowerShot SD870 IS Flash Assembly Replacement, Flash Assembly: 手順 16、 1の画像 1
    • Begin by removing two silver 0.080in screw on the left side of the camera.
  17. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 17、 1の画像 1
    • With the case, LCD screen, and release button housing removed, the broken flash unit can be removed and replaced.
    • Begin by disconnecting the hanging flash/speaker unit from the connector on top of the camera.
  18. Canon PowerShot SD870 IS Flash Assembly Replacement: 手順 18、 1の画像 1
    • Next, gently disconnect the plastic piece on top of the flash/speaker wiring by prying open the claws on either side.
    • The flash unit can now be removed and replaced.
    • Be careful not to touch the capacitor attached to the flash unit as it may still be holding a charge!
終わりに
作成者
3人の作成者と共同で作成されました。
Sam
メンバー登録日: 04/15/10
155 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-45, Garner Spring 2010 Cal Poly, Team 10-45, Garner Spring 2010人のメンバー
CPSU-GARNER-S10S10G45
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 4,934
