メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Canon PowerShot SD850 IS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 手順 1、 3の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 手順 1、 3の画像 2 Canon PowerShot SD850 IS LCD Screen Replacement, Battery: 手順 1、 3の画像 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 2、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 2、 2の画像 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS LCD Screen Replacement, Case: 手順 3、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement, Case: 手順 3、 2の画像 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 4、 3の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 4、 3の画像 2 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 4、 3の画像 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 5、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 5、 2の画像 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 6、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 6、 2の画像 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 7、 1の画像 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 8、 1の画像 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS LCD Screen Replacement, LCD Screen: 手順 9、 1の画像 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  10. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 10、 1の画像 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  11. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 11、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 11、 2の画像 2
    • Remove the two metal frames that hold the LCD panel in place.
  12. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 12、 1の画像 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  13. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 13、 1の画像 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  14. Canon PowerShot SD850 IS LCD Screen Replacement: 手順 14、 2の画像 1 Canon PowerShot SD850 IS LCD Screen Replacement: 手順 14、 2の画像 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Peter Tran
メンバー登録日: 10/06/10
252 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-7, Maness Fall 2010 Cal Poly, Team 20-7, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S20G7
6 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 32
今までの合計 4,491
