はじめに
Use this guide to remove a broken camera lens from your Canon PowerShot SD850 IS.
必要な工具と部品
The LCD screen should now only be attached by two LCD data cables.
Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
Carefully slide the data cable out of the connector.
The LCD should still be connected by the backlight cable.
To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
Carefully slide out the backlight cable.
The LCD screen can now be fully detached from the camera body.
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
Remove four screws located on the back of the camera:
6.15 mm #00 Phillips
2.75 mm #00 Phillips
2.15 mm #00 Phillips
2.7 mm #00 Phillips
3 の人々がこのガイドを完成させました。
コメント 1 件
If you have a problem on your camera then it is better if you go nearest technician to fix your camera.
Get a good action camera at http://actionshotcam.com
