メインコンテンツにスキップ
Canon PowerShot SD780 IS LCD Screen Replacement
必要な工具と部品
  1. Canon PowerShot SD780 IS LCD Screen Replacement, LCD Screen: 手順 1、 1の画像 1
    • Turn the camera off by pressing the power button.
    • Also, make sure the battery is removed, as to avoid any shock injuries. To remove the battery located at the bottom corner of the camera, slide the panel towards the corner. Push the orange tab upwards and remove the battery.
  2. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 2、 2の画像 1 Canon PowerShot SD780 IS LCD Screen Replacement: 手順 2、 2の画像 2
    • Remove five screws from the camera casing using a Phillips #00 screwdriver.
    • There are two 2 mm screws located on the left side of the camera.
  3. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the front panel of the camera case to expose the top left copper strip.
    • Gently pull the copper strip upward and disconnect it from the camera.
  4. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 4、 1の画像 1
    • Remove the screw on the far left-hand side of the front of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 5、 1の画像 1
    • Carefully pull the case apart at the seam. The case will detach from the camera in two pieces.
  6. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove the indicated "L" shaped bracket from around the bottom and right side of the LCD screen.
  7. Canon PowerShot SD780 IS LCD Screen Replacement: 手順 7、 1の画像 1
    • Insert the flat side of your spudger tool carefully into the top of the LCD screen and lift the screen free.
    • Set the broken screen aside and place the new screen on top of the LCD screen.
終わりに
作成者
12人の作成者と共同で作成されました。
Arlene Ale
メンバー登録日: 03/13/14
455 ポイント
4のガイドは作成済み
チーム
New Mexico State, Team 1-5, Easley Spring 2014 New Mexico State, Team 1-5, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G5
2 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 18
今までの合計 1,342
