メインコンテンツにスキップ
Canon PowerShot SD780 IS Flash Capacitor Replacement
必要な工具と部品
    • Begin by making sure the camera is turned off and the battery has been removed to avoid any shock injuries.
  1. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 2、 2の画像 1 Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 2、 2の画像 2
    • Having removed the battery, you can begin removing the outermost screws on the camera to allow for case replacement. There are 5 screws in total. This will require a Philips head # 00 screwdriver.
    • Keep track of where each screw came from in order to avoid complications during the reassemble process.
    • The screws highlighted by the red square in the second image (on the left side in the first image) are 2.0 mm long.
  2. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 3、 1の画像 1
    • Remove the front panel of the camera case to expose the top left copper strip, and gently pull the strip upward to disconnect from camera.
  3. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 4、 1の画像 1
    • Remove the screw on the far left hand side of the camera.
  4. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 5、 1の画像 1
    • Now that you have removed all of the screws, carefully pull the case apart at the seem. The case will detach from the camera in two pieces.
  5. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 6、 1の画像 1
    • Locate the image stabilizer on the top right of the camera and pry the internal battery away from the camera. Having done this, the internal battery can be removed easily.
  6. Canon PowerShot SD780 IS Flash Capacitor Replacement: 手順 7、 1の画像 1
    • You have now exposed the internal battery, and you may proceed to exchange the old internal battery for a new one.
終わりに
ある他の人がこのガイドを完成しました。
作成者
14人の作成者と共同で作成されました。
Arlene Ale
メンバー登録日: 03/13/14
455 ポイント
4のガイドは作成済み
チーム
New Mexico State, Team 1-5, Easley Spring 2014 New Mexico State, Team 1-5, Easley Spring 2014人のメンバー
NMSU-EASLEY-S14S1G5
2 メンバー
4のガイドは作成済み
コメント 1 件
what is the number for the replacement battery?
peterprosser - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 895
