メインコンテンツにスキップ
Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement
必要な工具と部品
  1. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 2、 2の画像 1 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 2、 2の画像 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: 手順 3、 2の画像 1 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Front and Rear Casing: 手順 3、 2の画像 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 4、 1の画像 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 5、 1の画像 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 6、 1の画像 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 7、 1の画像 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 8、 1の画像 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 9、 2の画像 1 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 9、 2の画像 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Button Contact Panel: 手順 10、 1の画像 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 11、 1の画像 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 12、 3の画像 1 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 12、 3の画像 2 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 12、 3の画像 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, LCD: 手順 13、 1の画像 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 14、 1の画像 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 15、 2の画像 1 Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 15、 2の画像 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement, Flash Bulb Assembly: 手順 16、 1の画像 1
    • Arrange camera so it is facing up towards you.
    • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
  17. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 17、 1の画像 1
    • Gently remove the indicated ribbon from respective ribbon gates.
  18. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 18、 1の画像 1
    • Place spudger under white connector and gently lift it vertically out of its slot.
    • Be careful not to damage wire connector during removal.
  19. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 19、 1の画像 1
    • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  20. Canon PowerShot SD500 Digital ELPH Flash Bulb Assembly Replacement: 手順 20、 1の画像 1
    • Gently pull away flash bulb assembly from the rest of the camera.
    • Be careful not to damage the ribbon on the rest of the camera.
終わりに
作成者
3人の作成者と共同で作成されました。
Taylor Shields
メンバー登録日: 10/13/14
846 ポイント
8のガイドは作成済み
チーム
Clemson, Team 2-1, Benson Fall 2014 Clemson, Team 2-1, Benson Fall 2014人のメンバー
CLEM-BENSON-F14S2G1
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 245
