はじめに
You need to remove the casing before you can start getting into any internal parts of the Camera. This can also be a good start to helping the camera dry out in case of a water accident.
パーツ
パーツは必要ありません。
  1. Remove the battery and SD Card from their slots.  Leaving these in could cause the battery to ground and ruin the electronics.
    • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
    • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
  2. Pull the lanyard mount off of the camera using a spudger or your fingers.
    • Pull the lanyard mount off of the camera using a spudger or your fingers.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Find the line that separates the casing into its two halves.  Hold each half seperately, and gently pull apart. Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
    • Find the line that separates the casing into its two halves. Hold each half seperately, and gently pull apart.
    • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
  5. Take hold of the inside of the camera, and gently pull away from the back casing.
    • Take hold of the inside of the camera, and gently pull away from the back casing.
  6. Remove the square, clear, rubber protector from the front of the logic board.  This is not necessary to remove, but can easily fall off and get lost during later steps.
    • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
  7. When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
    • When you reassemble the camera, make sure the switch on the casing (pictured left) matches the position of the switch on the camera internals.
    • The black viewfinder padding (pictured right) can easily fall off the casing. Make sure you don't lose it when moving around parts.
まとめ
ある他の人がこのガイドを完成しました。
Curtis Wagner
メンバー登録日: 2010年04月10日
29 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 25-85, Amido Spring 2010 Cal Poly, Team 25-85, Amido Spring 2010人のメンバー
CPSU-AMIDO-S10S25G85
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 3,383
