メインコンテンツにスキップ
Canon PowerShot SD30 Motherboard Replacement
必要な工具と部品
  1. Canon PowerShot SD30 Motherboard Replacement, Back Cover: 手順 1、 3の画像 1 Canon PowerShot SD30 Motherboard Replacement, Back Cover: 手順 1、 3の画像 2 Canon PowerShot SD30 Motherboard Replacement, Back Cover: 手順 1、 3の画像 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  2. Canon PowerShot SD30 Motherboard Replacement: 手順 2、 1の画像 1
    • Gently remove the back cover.
  3. Canon PowerShot SD30 Motherboard Replacement, Front Cover: 手順 3、 2の画像 1 Canon PowerShot SD30 Motherboard Replacement, Front Cover: 手順 3、 2の画像 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  4. Canon PowerShot SD30 Motherboard Replacement: 手順 4、 1の画像 1
    • Gently remove the front cover.
  5. Canon PowerShot SD30 Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Canon PowerShot SD30 Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • Unscrew the 3mm silver screw from the top of the camera.
    • Gently remove the top button panel.
  6. Canon PowerShot SD30 Motherboard Replacement: 手順 6、 2の画像 1 Canon PowerShot SD30 Motherboard Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using the tweezers, carefully lift up the 2 folds where the ribbon connects to the motherboard.
    • Now, lift up the three remaining ribbon connectors to disconnect them.
  7. Canon PowerShot SD30 Motherboard Replacement: 手順 7、 1の画像 1
    • Unscrew the three 3mm silver screws from the motherboard.
  8. Canon PowerShot SD30 Motherboard Replacement: 手順 8、 3の画像 1 Canon PowerShot SD30 Motherboard Replacement: 手順 8、 3の画像 2 Canon PowerShot SD30 Motherboard Replacement: 手順 8、 3の画像 3
    • Gently pull the left wire out and disconnect it from the device.
    • Use the tweezers to pop the right set of wires out of the connector. Do this by positioning the tweezers under the connector and lifting up.
  9. Canon PowerShot SD30 Motherboard Replacement: 手順 9、 1の画像 1
    • Remove the motherboard from the device.
    • The motherboard will have nothing connecting it to anything, so be sure to have it grasped.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Ime Ekpo
メンバー登録日: 09/21/18
479 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S5-G3, Thompson Fall 2018 University of North Texas, Team S5-G3, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 166
