はじめに
This guide is required in order to replace any other component that needs replacing. You cannot access any other component if the front cover is attached.
必要な工具と部品
Remove the two 2mm black screws that are located on the underside of the camera.
Remove the two 3mm silver screws from the right side of camera.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
