メインコンテンツにスキップ
Canon PowerShot SD30 Control Panel Replacement
必要な工具と部品
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: 手順 1、 2の画像 1 Canon PowerShot SD30 Control Panel Replacement, Front Cover: 手順 1、 2の画像 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: 手順 2、 1の画像 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: 手順 3、 3の画像 1 Canon PowerShot SD30 Control Panel Replacement, Back Cover: 手順 3、 3の画像 2 Canon PowerShot SD30 Control Panel Replacement, Back Cover: 手順 3、 3の画像 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: 手順 4、 1の画像 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: 手順 5、 3の画像 1 Canon PowerShot SD30 Control Panel Replacement, Control Panel: 手順 5、 3の画像 2 Canon PowerShot SD30 Control Panel Replacement, Control Panel: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: 手順 6、 3の画像 1 Canon PowerShot SD30 Control Panel Replacement: 手順 6、 3の画像 2 Canon PowerShot SD30 Control Panel Replacement: 手順 6、 3の画像 3
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: 手順 7、 1の画像 1
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: 手順 8、 1の画像 1
    • Remove the control panel from the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Diego Hughes
メンバー登録日: 09/21/18
139 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S5-G3, Thompson Fall 2018 University of North Texas, Team S5-G3, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G3
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 367
