メインコンテンツにスキップ
Canon PowerShot SD1400 IS Image Capture Button Replacement
必要な工具と部品
  1. Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 手順 1、 2の画像 1 Canon PowerShot SD1400 IS Image Capture Button Replacement, Image Capture Button: 手順 1、 2の画像 2
    • Use a Phillips #00 driver to remove the four 2.0 mm Phillips screws on the camera housing.
    • There are two screws on either side.
  2. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 2、 1の画像 1
    • Use a Phillips #1 driver to remove the one 4.0 mm Phillips screw located on the bottom of the camera.
  3. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 3、 1の画像 1
    • Remove the face housing from the body of the camera.
  4. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 4、 1の画像 1
    • Turn the camera over and remove the rear housing.
  5. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 5、 1の画像 1
    • Remove the button panel if it did not fall out on its own.
  6. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 6、 1の画像 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips copper screw from the top of the camera.
    • This screw is only visible after the front and rear panels have been removed.
  7. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 7、 1の画像 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips silver screw from the rear face of the camera.
  8. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 8、 1の画像 1
    • Use a plastic spudger to lift the golden film off of the microchip on the front face of the camera, exposing a screw.
  9. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 9、 1の画像 1
    • Use a Phillips #0 driver to remove the one 3.0 mm Phillips screw.
  10. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 10、 2の画像 1 Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 10、 2の画像 2
    • Use a metal spudger to carefully pry the small black tab away from the connector that secures one end of the golden film.
    • When fully released, the small black tab will stand up straight from the face of the camera and the golden film will no longer be secured.
  11. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 11、 1の画像 1
    • Carefully insert a metal spudger under the two clusters of wires that are plugged into the small chip on the face of the camera.
    • One cluster of wires is red, the other cluster is black.
    • Pull the wires parallel to the face of the camera to disconnect them from the small chip.
  12. Canon PowerShot SD1400 IS Image Capture Button Replacement: 手順 12、 1の画像 1
    • The image capture button housing can now be removed from the body of the camera and replaced.
終わりに
Follow these instructions in reverse order to reassemble the device.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Braxton Beal
メンバー登録日: 01/30/18
702 ポイント
3のガイドは作成済み
チーム
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S1G3
3 メンバー
4のガイドは作成済み
1件のガイドコメント
Where can do you buy replacement parts?
Chase Mahard - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 449
