メインコンテンツにスキップ
Canon PowerShot SD1200 IS Motherboard
必要な工具と部品
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: 手順 1、 1の画像 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: 手順 2、 3の画像 1 Canon PowerShot SD1200 IS Motherboard: 手順 2、 3の画像 2 Canon PowerShot SD1200 IS Motherboard: 手順 2、 3の画像 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: 手順 3、 2の画像 1 Canon PowerShot SD1200 IS Motherboard: 手順 3、 2の画像 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: 手順 4、 1の画像 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: 手順 5、 1の画像 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: 手順 6、 2の画像 1 Canon PowerShot SD1200 IS Motherboard: 手順 6、 2の画像 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: 手順 7、 1の画像 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: 手順 8、 1の画像 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: 手順 9、 1の画像 1
    • Lift out the motherboard.
終わりに
作成者
4人の作成者と共同で作成されました。
Jeff Casper
メンバー登録日: 09/15/16
848 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 17-5, Blackwell Fall 2016 USF Tampa, Team 17-5, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S17G5
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 13
今までの合計 417
