必要な工具と部品
Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
With spudger gently remove the Viewfinder Window that is directly above the lens.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
