Push the metal frame away from the metal tab using the spudger to detach the frame.
Rotate the metal frame upwards.
The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
Carefully lift the metal frame from the camera.
Remove the black LCD screen, leaving the thin lens pieces in place.
BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
Carefully pull on the orange connector ribbon to disconnect the LCD screen.
The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
Tweezers are helpful to disconnect the ribbon.
Detach the mother board with lens from body of camera.
Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
Your lens has been removed from the motherboard and bottom framing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
